Transient Results File Reading using MATLAB
Old   November 21, 2017, 05:50
Question Transient Results File Reading using MATLAB
Faber Yosua Octavianus
abrosua is on a distinguished road
Hello guys, i'm working on FSI project of a transient bending wing analysis.
I want to obtain the aerodynamics characteristics (example: CL, CD and Cm) and also the spanwise lift distribution of the results for each time steps.
I also want to use MATLAB to access and read the output file from the CFX, so that I can process the results that I need using MATLAB, such as plotting the graph, etc.
Do you guys have any suggestions or references in order to solve this case?
Thank you for your attention.
Regards
abrosua is offline   Reply With Quote
Old   November 21, 2017, 11:11
Maxim
-Maxim- is on a distinguished road
1. create monitor points for the desired variables (cl, cd, etc.)
2. use command line tool "cfx5mondata" to save monitor points as *.csv (look up the use of cfx5mondata in the manual/help or search this forum).
3. import the *.csv in Matlab
That's my work flow as well. All handling of the data (averaging, calculations, creating&saving graphs, writing Excel files, etc.) is done with some Matlab routines I've written myself.
-Maxim- is offline   Reply With Quote
Old   November 23, 2017, 06:10
Thanks for your suggestions, it really helps.
Another question, what if I want to extract the data outside the monitor points? Are there any methods to obtain it simultaneously?
Regards
Old   November 23, 2017, 06:13
Maxim
You're welcome.
What kind of data outside the monitor points are you thinking of?
via cfx5mondata -showvars you can see all possible variables, that the mondata routine can extract.
cfx, fsi, matlab codes for cfd, transient
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 10:07
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 18:18
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 12:32
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 12:46
