April 25, 2003, 07:25 |
Creat Surface
Dear All,
I've encountered a problem that I like to create a surface which bound by a irregular polygon, how can i create that surface? firstly i have built several curves for the polygon, and what's the next for the surface? please help! thanks! Donna |
April 25, 2003, 08:26 |
Re: Creat Surface
chain the curves you built to one curve,than creat a trimmed surface with the curve,good luck!
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 12:12 |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 12:05 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 03:09 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 13:43 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
