total heat lost in transient simulation
Old   November 5, 2017, 09:18
Default total heat lost in transient simulation
sortik is on a distinguished road
Hello everyone how can one calculate total heat loss by object that is cooled down due to natural convection. I have simple square box with temperature set to 60C. it is in air enclosure with no flow and temperature of 22C. Simulation itself is ok and results also seems ok but I can't figure how can I determine how much heat in watts the object lost. I can tell the heat that is generated in every step with
areaInt(wall heat flux)@boundary
but its just the actual amount in actual step.
Is it possible to tell that the object lost X watts from the beggining till the end? And would this also be possible to compute in steady state simulation?
I am just starting doing simulations and for sure I am not expert in thermodynamics so please be gentle Thank you very much
sortik is offline   Reply With Quote
Old   November 5, 2017, 17:20
You will need to get the time history of the wall heat flux and then integrate it over time. To do this:
* Define a monitor point with the areaInt(wall heat flux)@boundary expression
* Run the simulation
* When completed, in solver manager make a plot monitor of that expression and export it to a CSV file
* Import the CSV file into your choice of mathematical software (matlab, python, excel) and do the time integration of the function. I trust you have some basic numerical mathematics background so you can do simple integrations like this.
Old   November 6, 2017, 09:02
Default average of all values
Thank you for your reply. I have a polypropylene box that weights 0.52kg. It is cooled down from 60C to 22C. With basic math I get that it should lost 10.15 watts of heat. If I set up my monitor variable of integer of wall heat flux I get numbers from 27 watts to 0 with timestep of 10 seconds. If I integrete these values I will get high number is it because i have to put timesteps into hours because integral of wall heat fluxg gives value of watts/h?
Thank you again
Old   November 6, 2017, 18:14
If you integrate Watts in time you get Watt.seconds, which is Joules.
You will need to convert hours to seconds - but I trust you already knew that.
heat flux, heat losses, natural convection
Problem in initializing transient simulation with a finer mesh sidd CFX 8 April 29, 2016 03:25
restarting paused transient simulation using reactingFoam JMDag2004 OpenFOAM Running, Solving & CFD 1 August 10, 2015 11:15
New guy trying to solve his first simple Heat Transfer simulation. BhaluBear OpenFOAM 2 August 12, 2014 13:54
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Simulation on Heat Sink Ken Adams FLUENT 4 June 26, 2007 17:03
