November 5, 2017, 07:20 |
wave current interaction
Noman Hafeez
Rep Power: 9 |
hello to all, i am simulating a turbine and i want to see the effect of waves on turbine.how can i simulate the wave over a inlet velocity as an inlet boundry condition??
November 5, 2017, 17:23 |
Rep Power: 144 |
What sort of wave? Shock wave, water surface wave, pressure wave?
What sort of turbine? Aeroengine, power generation turbine, pump? But the principle is the same, regardless of the details. Make the inlet variables a function of time and define a function which describes your input wave. |
Current density visualisation (PEM fuel cell add-on module) | pchoopanya | FLUENT | 10 | August 21, 2023 15:33 |
Shock Wave Boundary Layer Interaction | AshwaniAssam | Main CFD Forum | 0 | July 3, 2017 08:58 |
CFD in Naval Hydrodynamics, Off-Shore and Wave Modelling with OpenFOAM | hjasak | OpenFOAM Announcements from Other Sources | 2 | February 13, 2017 05:59 |
Appropriate solver for investigation interaction of wave flow field on a structure? | mmbeik | OpenFOAM Running, Solving & CFD | 6 | July 3, 2015 08:24 |
Wave with Current inflow | jiko | FLOW-3D | 0 | January 9, 2015 12:08 |
