Defined inlet velocity is different with inlet velocity on CFX post |
November 2, 2017, 07:52 |
Jonathan
Hi there,
I'm new to CFD, and I got problems with CFX post as I don't get my expected results. My project is simulating flow over a FSAE car to obtain drag and down force.I made the boundary with enclosure on DesignModeller. I specified inlet velocity as 60 km/h, after the simulation finished I checked the velocity at the inlet using function calculator> sum> velocity, which shows 2150 m/s. How could this happened as I specified a constant speed at inlet? Thank you |
November 2, 2017, 08:37 |
urosgrivc
Rep Power: 12 |
Hi
Why did you use sum? use >area average>velocity what does velocity contour look like if you make a plane, does it look like 60, or something else at an inlet? It is almost never the softwares fault, its just a computer it doesent know enithig, the person who uses it gives it all the data and guidance. When I first started using cfx I was the same, blame it on the cfx, now I know that I just ditnt know ewerithing and I still dont know a lot but I know that if something is wrong it is most probably my fault and not the number crunching machine. This is some life advice that can be implemented in a lot of other cases asveal I was a FSAE car designer for about 4 years, so I realy hope you make it work and get some good results. I suggest you use monitor points for drag and downforce and let your convergence criteria be primarely based on these monitor points and not just residuals. Last edited by urosgrivc; November 2, 2017 at 09:52. |
November 2, 2017, 17:40 |
Rep Power: 144 |
The sum function does just that, it sums. So if you have 500 nodes each at 4m/s it will sum to 2000m/s. This is a pretty useless calculation and I suspect it is not what you wanted.
I think you are looking for averaging functions. areaAve or massflowAve look like better choices to me. |
cfx, cfx post |
VOF Volume fraction in Velocity inlet | aruelle | FLUENT | 2 | May 10, 2024 11:17 |
VELOCITY vs VELOCITY IN STN FRAME vs RELATIVE VELOCITY | everest20 | FLUENT | 1 | July 13, 2015 09:35 |
Velocity in porous domain in CFX post | Chander | CFX | 5 | May 20, 2015 05:12 |
velocity inlet and ideal gas simultaneously-what's wrong? | preetam69 | FLUENT | 0 | September 28, 2013 05:51 |
Velocity inlet boundary condition for porous medium | Chander | CFX | 3 | March 11, 2012 22:18 |
