March 3, 2003, 13:33 |
coordinate frame
Hi all,
In order to create a swirl in a flow. I like to put a radial momentum source on my cylinder subdomain. All goemetric solids are created in rectangular coordinate including this subdomain. Then I created a new cylindrical coordinate and choose it to be a reference coordinate of subdomain. But when I set the momentum source in the fluid source form, It's appear that the form still require a momentum value in x,y and z component. Do I have to create a geometric solids in cylindrical coordinate or not? Could anybody suggest me how to set a momentum source in cylindrical coordinate please. Thank you all in advance. Jackie -_-" |
March 4, 2003, 19:15 |
Re: coordinate frame
Hi Jackie
I'm assuming you're using CFX-5, and I think the following is true: a) At present, all coordinate frames (even cylindrical ones) get treated as cartesian rectangular in the Solver, so defining and using a cylindrical frame in Build will not help. b) A possible solution is to create a rectangular coordinate frame, and do the manual transformation from r and theta components to X and Y components. Tutorial 11 shows how to do this for a rotating wall velocity. Regards, Sharks |
March 6, 2003, 01:22 |
Thank you very much Sharks. ^_^
Jackie |
CFD Post- coordinate frame issue | GSbert | ANSYS | 1 | June 15, 2012 02:26 |
Question about N-S eqs. in body fixed noninertial reference frame | doctorWho | Main CFD Forum | 0 | July 12, 2011 19:07 |
vorticity depends on non-inertia frame of referenc | dingxi | Main CFD Forum | 3 | October 18, 2006 14:13 |
ICEM5.1: how to hide coordinate in the display? | Tim | CFX | 0 | May 19, 2005 04:34 |
Cylindrical coordinate frame | New User | CFX | 3 | August 10, 2002 07:41 |
