users fortran USRBCS
Old   February 14, 2003, 10:00
Default users fortran USRBCS
cfx4.3 user
hello all
I would like to read inlet temperature profile from a matrix file for a transient flow (the 1st column is time and the second is temperature) using the fortran routine USRBCS at user area 5. Is there any one who knows howto do it in fortran. I mean calling a file or array defination....
thanks a lot
cfx 4.3 user
Old   March 3, 2003, 06:11
Default Re: users fortran USRBCS
Azeez
I am also trying to solve a similar problem. I want to fix my own temperature in the bounday condition at the start of every time step which is dependent on the reaction heat(flow with reaction) produced in the previous time step. the same applies to the pressure. if u managed to find a solution for ur problem can u please help me in solving this. thanks in advance. sincerely Azeez
Old   March 5, 2003, 19:02
Jeff
These are two slightly different problems:
CFX4.3 User ============ Open the file in USRINT and read the array of times and temperatures into arrays and store them in a common block. Then in USRBCS, you have access to the TIME variable. Compare this TIME variable to your time array and set the corresponding (or interpolated) inlet temperature on the boundary condition.
Azeez =========== Through the WORK array (see chapter 11 of the manual) you have access to the VAROLD stack. You can access all temperature and pressure values from the previous time step there. You can then use these values to set your current time step values.
NOTE: for both cases, make sure you set the BCSFLG so that the routine gets called for every iteration and timestep (this is a value of 3 I think). Usage of this flag is documented in the comments.
Cheers, Jeff
Fortran Compiler-CFX12.1 Araz CFX 13 March 27, 2017 06:37
visual fortran Monica Main CFD Forum 1 August 28, 2004 21:45
Why Favoring Fortran over C/C++? Zi-Wei Chiou Main CFD Forum 35 September 26, 2001 10:34
Fluent 5.5. What the differences with fluent 5.3?? confused FLUENT 2 July 29, 2001 22:58
2000 North American STAR-CD Users Conference Andrew Robertson Siemens 0 March 31, 2000 19:18
