February 7, 2003, 04:49 |
Meshing by specify a type and number of node
Hollo all
Could anyone can tell me. Is it posible to creat mesh in CFX5.5.1 by specifiy type of mesh (such as Hexahedral) and number of nodes in each direction. Thank you in advance. |
February 7, 2003, 05:39 |
Re: Meshing by specify a type and number of node
Yes, but you have to use the mesh only mode when you first generate the new data base. You also need to construct your geometry differently. You can not use Brep solids. All solids representing the domain must be six sided. There is a tutorial to show how to do this. Once the solid has been generated, and mesh implamented then you need to import the mesh into a new database in the import mesh only mode. This is all a little long winded, but I think things are going to be more simple in CFX5.6 ?? Bob
February 7, 2003, 11:00 |
I appreciate your kind answer to my questions Bob.
Jackie |
February 7, 2003, 11:47 |
Hi, Jackie, you can change the mesh mode from AFI to Patran Volume Meshing in "Preference" panel in the build, using structure mesh instead of unstructured one. That's it!
Hannah |
February 9, 2003, 09:59 |
Thank you very much Hannah ^_^
April 13, 2003, 16:54 |
hello how are you ? in fack im a student of mechanic engineering and I need a program about compresible flow I need a source code of a program that we give some jeometrics and it solve and give us numbers or information that we need thanks bye
second order schemes | marine | OpenFOAM | 67 | April 11, 2022 18:19 |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 12:55 |
Pressure instability with rhoSimpleFoam | daniel_mills | OpenFOAM Running, Solving & CFD | 44 | February 17, 2011 17:08 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
