problem defining material properties as a function of temperature
Old   October 19, 2017, 11:52
Default problem defining material properties as a function of temperature
ehsan
Ehsan301 is on a distinguished road
Hi, i'm working on a 2D simulation which contains a sodium flow and it's properties are function of temperature. i used expression to define them but when i run the solver it returns with error code 1 and fatal error on material properties.
when i use other materials like ideal gas air there is no problem so i think the problem is with the material properties.
i used these expressions:
Density : ((1012 [K] )-(0.23*T))*1 [kg m^-3 K^-1]
Dynamic viscosity : (88500 [K] - 94*T)*1 [Pa s K^-1]
Specific Heat Capacity : (1499 [K] - 0.33*T)*1 [J kg^-1 K^-2]
Thermal Expansivity : (20000 [K] + 10*T)*1 [K^-2]
Thermal Conductivity : (112.1 [K] - 0.064*T)*1 [W m^-1 K^-2]
and checked Temp.Extrapolation in material properties.
it's 2D Steady State simulation with velocity inlet and pressure outlet and a fixed temperature wall
Here is the file:
http://www.mediafire.com/file/ygk5oo...ODIUM_FLOW.rar
Ehsan301 is offline   Reply With Quote
Old   October 19, 2017, 16:01
Erik
evcelica is on a distinguished road
Looking at that viscosity expression, Wow!!! That is an incredibly high viscosity! 60 million times more viscous than water!
Your Thermal expansivity is WAY too high as well: 24000 [K^-1]!!!!
You can plot your expressions in CFX pre to check if you have them right. but these are definitely not correct.
Also:
Thermodynamic inconsistencies can arise from defining both density and specific heat as dependent variables.
Try making one of them constant.
You don't need variable density and thermal expansion. the thermal expansion will be ignored and you will use the full buoyancy model instead if you define variable density.
I'd make density constant, and just use the expansion for buoyancy (boussinesq approximation)
evcelica is offline   Reply With Quote
Old   October 19, 2017, 16:48
ehsan
i found the properties from an article:
it seems correct when i plot these expressions in cfx but when i use them to define the material even only one of them then the solver will give me error and won't start.
i also tried to use constant values near these, the solver wouldn't give error but it converged so fast and actually it didn't solve anything and gave me empty data.
Old   October 19, 2017, 17:33
ehsan
you are right, it was written 4.15*10^4 for viscosity in the article i found the properties from , but it should be 4.15*10^-4. i think that was the problem.
thanks
cfx, material error
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Simple piston movement in cylinder- fluid models arun1994 CFX 4 July 8, 2016 03:54
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 02:27
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
