January 26, 2003, 13:40 |
Total pressure drop
Hi all,
I am working on a system comprised of two triangular ducts intersecting each other at 90 degrees. There are two inlets and two outlets. At the intersection the flow gets diverted and a fraction of the flow coming from one inlet (say inlet 1) goes straight (outlet 1) and another fraction bends at 90 degrees and goes to outlet 2 . Same thing happens to flow from inlet 2. How to calculate the total pressure drop for this system. Regards, Swapnil. |
January 26, 2003, 18:56 |
Re: Total pressure drop
I guess that the difference of a volume average of the total pressure at the outlet and inlet could give the answer. (mass average will do if the flow is incompressible)
January 27, 2003, 10:21 |
Hi, Jan:
Did you compare the simulation results with real case? I compared the pressure drop. It seems the CFX results are smaller than that of regular method. fly |
January 27, 2003, 11:16 |
Hi, Fly:
I found the same result with you. And If I refine the mesh, the result even become smaller. Could you find the explaination from theory in books? Hannah |
January 27, 2003, 14:22 |
Hi fly and Hannah liang ,
are you people working on triangular ducts? |
January 27, 2003, 16:33 |
I would be surprised if the values was exactly the same. There are some uncertainities in both measurements and numerical results. I know it is very difficult to get exact numbers when looking for the pressure drop. I have had some succes with predicting pressure drop when using higher order differencing, double precision and doing a grid independency investigation and calculating an estimate of the pressure drop from a Richardson extrapolation of the pressure drop obtained with the three grids. Regards Jan
January 28, 2003, 09:38 |
Hi, Jan:
I agree with your on the pressure drop for measurements and numerical results. But I think they should be the same on some extend. Could you share your success results with me. Thanks SXF |
January 28, 2003, 13:27 |
Dear sxf, You state that "they should be the same on some extend". I do agree with you, what could I else ). But when will you say you are satisfied, 5% or 10% or 20% etc. What kind of accuracy should be expected from a numerical code with many assumptions and with many constants based on old experiments with an accuracy on???. I remember once a paper with different test cases where several numerical codes was investigated, but I do not remember the exact values , but one should not be surprised if there are some deviations. Regards Jan
buoyancy - losses estimation through total pressure | clrsgfn | CFX | 4 | November 10, 2010 11:05 |
Pressure drop? | Munni | FLUENT | 4 | March 25, 2010 14:21 |
total pressure in CFX | Atit Koonsrisuk | CFX | 0 | January 1, 2005 05:46 |
Total pressure to static pressure ratio | roadracer | Siemens | 1 | April 17, 2003 05:31 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
