January 23, 2003, 14:34 |
How to get compressibel flow inCFX 5.5
Iīm a student that trying to optimize a turbo-restrictor that we have to use in our Formula SAE car.I want to know how to specify in CFX5 that I want compressibel flow(canīt find any info in Tutorials and help menu)since the flow in the restrictor will be choked when the airspeed approaching Mach 1,so far I have used "Air ideal gas" but my massflow is to high to be accurate.
Thanks in advance. Thomas SWEDEN |
January 23, 2003, 16:22 |
Re: How to get compressible flow in CFX 5.5
Hi Thomas,
To model choked flow, you also need to use "Total Energy" as your heat transfer model in the fluid domain. Also, there are tutorials which use compressible flow - tutorial 8, "Supersonic flow over a wing" and tutorial 12, "Flow in an Axial Rotor/Stator Arrangement". Regards, Glenn Horrocks |
January 24, 2003, 14:19 |
Iīve tried to use "total energy" as heat transfer and I have looked at the tutorials mentioned but I canīt get it to work-and specifying supersonic didnīt work for me either. Maybe iīm doing something else wrong(I specify domain to:100kPa-Air ideal gas, and set the Boundary conditions to: inlet-100kPa and outlet to 52,8kPa that in teori should get M1 and choked flow-all air goes thru a convergent-divergent pipe with a 20mm minium diam.) looking forward to get some more info. regards Thomas
January 25, 2003, 02:49 |
You say you specify domain to 100kPa. This is OK, but you should understand that this is the reference pressure. All other pressures are relative to this. If you mean for your inlet to be 100kPa absolute, then you should specify the inlet value as 0 kPa. If you mean for your inlet to be 100kPa relative (i.e. 200kPa absolute in your case) then you already have the correct values. Similarly, the outlet pressure is relative to the reference pressure. Hope this helps, Mike
January 25, 2003, 04:06 |
That explain why my massflow was twice as high as expected, so now it should work with correct "Boundary conditions". Thank you for the help, Mike and Glenn regards Thomas
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 08:33 |
reversed flow at velocity inlet / mass flow inlet | ib | FLUENT | 1 | March 26, 2007 13:11 |
How to change from mass flow to volume flow rate | stanley | FLUENT | 1 | February 2, 2007 06:44 |
transform navier-stokes eq. to euler-eq. | pxyz | Main CFD Forum | 37 | July 7, 2006 08:42 |
Does anyone work at SIMPLE in unsteady and compressibel flow | Junl | Main CFD Forum | 1 | February 4, 2000 21:24 |
