CFX 5.5.1 and LES - maximal residuals
Old   January 21, 2003, 11:20
Default CFX 5.5.1 and LES - maximal residuals
Olivier Macchion
Hello everybody !
Is there someone who knows if it is possible to do Large Eddy Simulation in CFX 5.5.1 ?
On another subject : how do you know where the maximal residuals are when running a computation in CFX 5.5.1 and the solution oscillates a bit.
Thank you very much.
Olivier
Old   January 21, 2003, 15:07
Default Re: CFX 5.5.1 and LES - maximal residuals
Holidays
Yes it is! Look in the RULES file and talk to your support.
Old   January 22, 2003, 05:29
bogesz
LES: I don't know nothing about that, but i suppose not.
location of max res: at about the end of the .out file there's a section with "Location of max. residuals" (printing out the node No. and the coordinates (xyz))
or you can edit your def/res file and do "add expert parameter section" + "add parameter" + "output eq. residuals" then run some more steps and plot it in post (the residuals will be available as variables)
Old   January 22, 2003, 05:33
Olivier Macchion
Thank you bogezc !
Olivier
Old   January 22, 2003, 06:43
Jan Rusås
It is possible to do LES with CFX5. I would advice you to do a search in the CFX forum, and you will see a number of responses to that question.
LES in CFX colen CFX 2 July 5, 2010 10:43
CFX 11 Scheme for LES in Multiphase Man CFX 12 May 25, 2009 21:26
LES in Fluent and CFX taedeneo Main CFD Forum 2 May 6, 2008 14:53
LES of Non-Premixed Combustion in CFX?? Manu CFX 5 February 25, 2008 17:34
CFX 5.5.1 stirred tank and LES problem Nishant CFX 2 September 13, 2002 08:11
