Opening closing and opening periodically with time
Old   October 13, 2017, 01:15
Lightbulb Opening closing and opening periodically with time
Raniel Albuquerque
ranield is on a distinguished road
Hello Folks!
I'm modeling an equipment to separate oil emulsified in water, the equipment consists to force the fluids to pass through a porous media, doing the tiny oil's droplets become together, which does the droplets increase it's diameter, doing the droplets to float, by the difference of density.
So, at the end of my equipment I need to have two openings: one at the top (for the oil) and another at the botton (for the water).
My problem is that the oil's opening will not be open all the time, I need to acumulate oil at the top, so, after a pre-defined time, that opening will be opened.
I tried to create two flow analysis, at the first one the oil's opening was closed, so at the moment "X" that analysis would end up and the second analysis would start (initial time = X), but that didn't worked out, the solver just runned the first one.
Somebody could help me with this problem (to couple the two analysis) or has another way to open the opening after a time?
ranield is offline   Reply With Quote
Old   October 13, 2017, 03:02
The simplest way of doing this is to do an initial simulation with it closed and then a second simulation with it open. I think this is what you are trying to do.
To do this you will need to make the results file in the first simulation the initial condition of the second simulation.
boundary condition, multi phase flow, transient analysis
dynamic mesh: UDF to simulate opening and closing door sinvastil FLUENT 1 March 16, 2021 03:18
[swak4Foam] groovyBC for simulating the opening and closing of a valve will_ca OpenFOAM Community Contributions 1 February 17, 2015 07:27
Help with writing a macro/UDF_file/script to change BC at regular time step intervals Codophobia Fluent Multiphase 0 April 24, 2014 11:07
Door opening and closing Rana FLUENT 5 May 3, 2010 09:09
BC for opening and closing valve? Luk FLUENT 7 May 27, 2006 16:40
