October 13, 2017, 00:41 |
Residuals non convergence
jinzhihui
Rep Power: 9 |
I have been working with CFX on steady-state simulation of an object shaped like an ellipsoid. During the grid generationg,because the geometry is complicated,computational domain is devided into several domains and the interfaces are set correctly. The boundary conditions were defined as follows. The inlet boundary was set to normal speed and the averaged static pressure was specified at the outlet.The other boundary condition were defined correctly. During the steady state solution, the residual is oscillating as the figure 1 shows below.Maybe the figure 2 is what we expect. I appreciate any information you could give to help me understand this issue |
October 13, 2017, 02:59 |
Rep Power: 144 |
Your images are not attached.
But your question sounds like this FAQ: https://www.cfd-online.com/Wiki/Ansy...gence_criteria |
October 13, 2017, 07:20 |
#3 | |
jinzhihui
Rep Power: 9 |
residuals non convergence |
Continuity convergence issue on a 3d wing | Nick R | FLUENT | 19 | April 6, 2020 15:52 |
under-relaxation factors -> level of residuals | Zigainer | FLUENT | 19 | July 21, 2017 17:53 |
Convergence issue- residuals of continuity | s.garg | FLUENT | 4 | November 7, 2016 12:39 |
Is solution converged?(Judging convergence)? | aja1345 | FLUENT | 4 | February 26, 2016 07:09 |
SIMPLE BCs for flow in parallel plates | kabz | Main CFD Forum | 23 | September 21, 2015 11:31 |
