Fluid-structure coupling problem
Old   January 16, 2003, 23:30
Default Fluid-structure coupling problem
bluebird
Dear Sir or Madam, I am researching on the squeeze flow computation in mechanical heart valve. Someone has used Fidap and Cfd-ace to deal this fluid-structure interaction problem. I want to know the advantages and disadvantages for these two codes in this problem. And someone who has other good suggestions, would you kindly reply me? Thanks.
Old   January 17, 2003, 06:46
Default Re: Fluid-structure coupling problem
Bob
Try speaking to the CFX vendors at AeA. They will be able to advise you on how they have been looking at the problem within CFX.
If you had a problem inputting your own peng-rob fluid Anthony_impeller CFX 1 June 15, 2013 07:57
Fluid Structure Interaction Apollo Main CFD Forum 5 July 4, 2011 17:15
Two Fluid bouyant problem and mesh DariusBic FLOW-3D 0 May 12, 2011 07:49
the influent of fluid on structure safarieduo FLUENT 0 April 28, 2011 13:24
Fluid Structure Interaction in Fluent Florian FLUENT 0 August 28, 2006 21:58
