January 13, 2003, 11:46 |
mesh quality
Does anybody have some idea of how to check the mesh quality for CFX. Thanks in advance.
sxf |
January 13, 2003, 14:23 |
Re: mesh quality
There a number of options in CFX-Post such as edge length ratio, volume ratio, face angle etc.
January 15, 2003, 19:24 |
Element Volume Ratio
I found the range of Element Volume Ratio of my mesh is between 1 to 40, and in a certain Plane, the area EVR>5 is up to 30%. Connectivity Number is between 2 and 64. (I also found in example 2, staticmixer_finemesh, has a similar situation. While according to "tool_menu.pdf" in manual, page 140, EVR higher than 5 may cause problem. I was confused.)
Sometimes I experienced problems with the flow field and convergence, is it a possible reason? How do you think the importance of EVR, CN and other mesh parameters? How can I improve this? Waiting for your suggestions and opnions. |
January 17, 2003, 17:25 |
Re: Element Volume Ratio
can anyone give me some hints here?
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
[ICEM] trouble with mesh quality from ICEM in CFX Solver | escher25 | ANSYS Meshing & Geometry | 0 | February 28, 2011 07:38 |
[snappyHexMesh] mesh quality control and fix | tachyon_me | OpenFOAM Meshing & Mesh Conversion | 0 | October 6, 2009 12:48 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
