Flow in a thin nozzle
Old   January 10, 2003, 04:42
Default Flow in a thin nozzle
Saso Prijatelj
Hi.
I'm working on simulation of air-flow through an inlet duct and a valve into a cylinder of a diesel engine. I'm trying to determine the flow coefficient (that's ratio between actual and theoretical air-flow through a nozzle) and compare it with experimental results I have obtained. I use CFX5.5. Simulation are static (they are done for different openings of valve). Does anyone have any experience with modelling flow in very thin nozzle (when the valve openening is less than 0.5mm) where "happening" in boundery layer has great effects on overall mass flow.
Any help will be appreciated.
Best regards,
Sašo Prijatelj.
Reversed flow error with thin film heater MK FLUENT 1 February 12, 2009 11:26
reversed flow over thin plate qiaomei FLUENT 8 December 30, 2008 04:54
Nozzle flow simulation in inviscid and viscous Cath FLUENT 0 January 28, 2007 03:16
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
Verification of Supersonic Nozzle Flow Ali Khan FLUENT 0 October 12, 2000 08:53
