Hi !
Does anyone know how to write e.g. average velocity of simulation domain in the file ? Thanks, Andrej |
Did you mean you wanna export the file in .txt format. or .dat format? If it is, open your result in CFX-post and creat the plane or volume or point in the location you want and go to file/ export and then select the varibles, locations, and your file name you like to export the data into it. CFX will be export your data in dat format. good luck. ^_^ Jackie
circumferential pressure profile on outlet -> error when writing results | mhsr | CFX | 4 | September 1, 2017 05:28 |
Writing results to a .txt or .dat file | Kwiaci | FLUENT | 6 | March 20, 2011 17:52 |
cfx solver crash when writing results | siden | CFX | 1 | January 27, 2011 19:51 |
Error writing transient results in FSI | CFX | 1 | April 15, 2010 06:57 | |
Distributed parallel error in CFX 5.5.1 | bogesz | CFX | 6 | January 27, 2003 18:22 |
