How to time average my results?
Old   October 3, 2017, 05:10
Smile How to time average my results?
Roy
ROY4 is on a distinguished road
Hello everybody
I want to time average my results in CFX-Pre. I found some topics about it in this site and read them but it couldn't help me very well. I also couldn't find time averaging in tutorial. Because in one of the opinions I read I should define my (start averaging time- end averaging time) but I can't find such thing in any place. the only thing I can see is the attached picture.
my question is that:
Is ((arithmetic average)) time average?If it is so, why it doesn't have (start averaging time- end averaging time)? WHY IS IT DEFINED ON ITERATIONS?
By the way my time is 150 seconds and I want to average over the last 130 seconds. My time step is 0.05. If arithmetic time averaging is the place I should use for averaging my results, What should I put for start iteration list and stop iteration list?
ROY4 is offline   Reply With Quote
Old   October 3, 2017, 09:30
Erik
evcelica is on a distinguished road
Arithmetic average sounds like it just averages the numbers for all iterations with no time step weighting. You have constant time steps, so it is equal to a time average in your case.
Simulation Time/Time step = Iteration number
Starting Iteration:
20 sec / 0.05 sec = 400
Ending Iteration:
150 sec / 0.05 sec = 3000
The documentation will have more details I'm sure. I'm just guessing here.
evcelica is offline   Reply With Quote
Old   October 3, 2017, 11:49
Roy
Starting Iteration:
Ending Iteration:
dear evcelica
thank you so much for your answer. So what I understood from your opinion is that: using arithmetic average is appropriate for time averaging in my case because the time step is constant and does not change in solution procedure. right?
I'm curious What would happen if I have different time steps in my solution?
By the way, If I want to use my steady state solution as my initial guess. Where should I define it?
I thought that I can ignore using initial guess in CFX-Pre and in CFX-Solver in define run(attached picture) use my steady state results as initial guess. is that right?
Old   October 3, 2017, 17:33
Erik
Correct on all accounts as far as I understand.
If you had different time steps I'm guessing it would still just average the numbers without weighting them by time duration.
I would use "time integral" instead if you have different time steps.
See CFX-Pre user guide for all the information on these options and settings. It has all you would want to know and more.
Old   October 3, 2017, 17:37
Opaque will become famous soon enough
Time averaged values are time step weighted
Time_average = Sum ( phi_1 * dt_1 + phi_2 * dt_2 + ....) / Sum(dt_1 + dt_2 + ...)
= Sum (phi_1 * dt_1 + phi_2 * dt_2 + ....) / Total Time
It is not an arithmetic average.
Opaque is offline   Reply With Quote
Old   October 4, 2017, 18:05
Roy
DEAR Obaque
thanks for your answer;
but do you know how and where should I define it in CFX? is there any place I can do it?
Old   October 4, 2017, 18:08
Smile
Roy
dear evcelica
thanks for your answer. I'm using arithmetic average now. I wish it will be the expected definition I searched.
time average in cfx
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 30 November 6, 2023 22:00
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 14:58
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
