bouyancy driven flow
Old   December 16, 2002, 04:21
Default bouyancy driven flow
adrienne
Hi, i have problem about the setting for the bouyancy driven flow, how would know the simulation should neglect the bouyancy effect or not? Is the value of the y-axis acceleration is -9.81ms^2 at most of the time? how to determine the x- or z-axis acceleration? what should i put for the density reference?? is that the density of the fluid that i used in simulation? is there got anymore details tutorial about the bouyancy driven heat transfer?? thanks guys.... have a nice day!!!
Old   December 16, 2002, 08:04
Default Re: bouyancy driven flow
Holidays
In CFX it should apply to multiphase situations. If you look in the manual there should be recomendations so as how to set this up (both in CFX-4 and 5 manuals). If you are dealing with dispersed flows (bubbles) the ref density should be that of the dispersed phase; otherwise in FS cases, it should be that of the lighter fluid.
Old   December 16, 2002, 09:05
Bob
Hi what I think you need to do, and if anyone else would like to confirm this it would be great as I'm not 100%, you will need to define the acceleration due to gravity in only your y axis (if i understand what you have said?). Then define the buoyancy reference density 9assuming you are using the Thermal energy model) by looking at your ambient density and your max or min density, then adopting a reference density at about half way between the two. also have a look at the Help manual on advice on modelling, there is a section in the that may help (Page 469).
Old   December 17, 2002, 12:21
Holidays
Sorry I read too fast and missed the 'heat' bit, and of course answered for the wrong scenarii. Follow Bob's advice in your case indeed; please note however that all the info/hints Bob and I gave are in the manual I believe.
Old   December 17, 2002, 14:12
Atit Koonsrisuk
I am the newcomer of CFX. Surprisedly that I am trying to solve the problem that is bouyancy driven also. I think that there are something different to set the condition to solve bouyancy driven flow between CFX4 and CFX5.There is the tutorial about your question. It is tutorial No.6. And try to search for the word "bouyancy" or "Boussinesq" in the help, then you will get the good explanation on this. Hope this help.
Atit
Old   January 6, 2003, 09:55
Sascha Becker
You haveonly to inlcude the gravity vector as 0;0;-9.81 m/s^-2 if the accelaterion is perpendicular to z-axis. The buoyancy option shall be included in Command language otherwise it is neglected !
purely capillary pressure driven flow doubtsincfd Main CFD Forum 0 January 25, 2011 13:56
is there any parallel code for the famous Lid Driven Cavity flow? gholamghar Main CFD Forum 0 August 1, 2010 02:55
Buoyancy Driven Flow - HELP! Carlos FLUENT 2 October 11, 2007 03:35
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 06:44
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
