Drag coefficient CEL expression
Old   September 27, 2017, 17:55
Default Drag coefficient CEL expression
cfxtwophaseflow
sarrazs is on a distinguished road
I'm doing CFD for an air-water bubble column. I'm using Euler-Euler Model with no turbulence model. I want to use a user drag coefficient example Mei coefficient.
I defined :
relative velocity: Ur = sqrt((air. u-Water. u)^2+(air. v-Water. v)^2+(air. w-Water. w)^2)
Volume fraction : epsilon = air.vf
Reynolds number : Re = 2*Water.density*Ur*air.mean particle diameter/Water.viscosity+10^-17 (10^-17 is just to avoid zero division).
Drag coefficient CD= (16/Re)*(1+(2/((16/Re)+(3.315/sqrt(Re))+1))).
I'm getting this error :
| ERROR #001100279 has occurred in subroutine ErrAction.
| Message:
| Floating point exception: Overflow
| Message:
| Stopped in routine FPX: C_FPX_HANDLER
For the Ishii Zuber coefficient, which already exists in cfx, works great but not with the CEL expression Mei coefficient.
sarrazs is offline   Reply With Quote
Old   September 28, 2017, 03:48
Lance
Lance is on a distinguished road
Originally Posted by sarrazs View Post
Reynolds number : Re = 2*Water.density*Ur*air.mean particle diameter/(Water.viscosity+10^-17) (10^-17 is just to avoid zero division).
if you want to avoid division by zero you should add the parenthesis in bold - but why would Water.viscosity be zero?
Lance is offline   Reply With Quote
Old   September 28, 2017, 11:21
cfxtwophaseflow
Thank you Lance for your reply. I added 10^-17 to the reynold number not the viscosity. Initially, all velocities are zero and it may be at on point Ur=0 so I want to avoid zero division in the drag coefficient CD
Drag Coefficient for Ellipse Form (2D) Ketut Utama Main CFD Forum 8 December 11, 2014 12:03
problem with saving drag coefficient colopolo FLUENT 5 April 12, 2013 11:59
Post Processing Drag Coefficient squanto773 OpenFOAM Post-Processing 1 March 7, 2012 10:43
Plot drag coefficient against Y(distance) edwin FLUENT 0 February 4, 2008 10:41
Lift, Drag Vs time chart,calculations Jamesd69climber CFX 8 February 17, 2005 18:23
