CFX-5.5.1 and gcc-3.1 based linux distributions |
November 28, 2002, 05:26 |
Hello!
I'm using the linux version of CFX-5.5.1. Everything is fine, when using Suse 7.2 or Redhat 7.3. A few weeks ago we did an update towards Suse 8.1. Since then it is not possible to use CFX-Post; the CFX-Solver manager crashes when I try to export to fieldview. The cfx-support said, that it's a problem concerning the qt-libs (they are compiled using gcc-3.1, CFX is compiled using gcc-2.96). Did anyone try to run CFX on Redhat 8.0? As it is based on gcc-3.2, do I have to expect the same problems there? The support couldn't tell me. Greetings Michael |
November 28, 2002, 06:14 |
Re: CFX-5.5.1 and gcc-3.1 based linux distribution
Are you sure that is a gcc version problem? We run CFX-5.5.1 on a Slackware 8.1 using the 2.95.3 version of gcc and we've noted no problems at all. Regards, cfd guy |
November 28, 2002, 07:42 |
I think, the problem is that gcc 2.9x is binary incompatible with gcc 3.x.Slackware 8.1 is using 2.9x Version, which should be binary compatible to 2.96. I tried to install an old version of the qt-libs (compiled using gcc 2.9x) without success. Regards, Michael |
gcc and executable file from Mac to Linux | simone Marras | Main CFD Forum | 0 | April 8, 2007 15:49 |
CFX with GCC 4.1 | Adam | CFX | 1 | November 10, 2006 04:46 |
