CFX POST mpeg Revisited
Old   November 22, 2002, 04:43
Default CFX POST mpeg Revisited
henry
How do it get it solved in CFX Post?
buying software is out of the question,they won't allow that in college.
then why is there a mpeg option in CFX?
when it cannot create one properly?
Old   November 22, 2002, 07:35
Default Re: CFX POST mpeg Revisited
Michael Bo
It works fine here. Be sure to have the correct codec installed before viewing the files. I think the MPEG format is MPEG-II, which is the same used on DVD's. Otherwise you can use virtualdub to convert it to an other format.
Old   November 22, 2002, 12:42
cfd guy
CFX-Post works fine with me either. Suppose that you're working whithin a resolution of 1280x1024. I suppose that the main window of Post is maximized. If you also maximize your Viewer window you'll have, at least, a picture with about 900x800. I'm sure that in this resolution you won't be able to see your mpegs using the microsoft media player. Reduce the Viewer window and you won't get this problem anymore.
However if your problem is in the mpeg generation I'll suggest you to take a look on the tutorial provided by CFX-5.
Regards, cfd guy
How to get reynolds stress values in POST CFX syler3321 CFX 6 January 1, 2017 08:54
CFX post legend modification mactech001 CFX 3 December 25, 2011 23:12
CFX Post export problem jeff_F CFX 0 August 17, 2009 22:25
Chart Generation in CFX Post Vadim Baines-Jones CFX 2 August 28, 2007 10:14
ANSYS CFX POST State file Mechstud CFX 1 June 22, 2007 15:59
