November 20, 2002, 06:21 |
Modeling a fan with a momentum source
Hi guys,
I would like to model the flow between two rooms induced by a fan. To reduce the complex geometry of the fan, I would like to use a momentum source. I could use a source term for only the normal velocity but then the rotational nature of the flow is completely ignored. Does any one have experience with implementing a momentum source that generates a rotational flow which is more or less comparable to the outflow of a fan... Thank you all, Pascale. |
November 20, 2002, 11:57 |
Re: Modeling a fan with a momentum source
Set three momentum sources along the x and y and z directions. You could set them both as a fonction of your radius and angular location for more realism.
November 21, 2002, 17:33 |
Dear Holidays,
I already tried that option. I know how the desired velocities profiles look like but the translation to the momentum sources is difficult because the resulting velocities influence these sources. By trial and error you can get somewhere but I never get it right within 25%. Pascale |
momentum source term | zwdi | FLUENT | 14 | June 27, 2017 16:40 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 02:24 |
modeling a pump as momentum source | Priscila | CFX | 4 | June 6, 2007 11:08 |
UDFs for Scalar Eqn - Fluid/Solid HT | Greg Perkins | FLUENT | 0 | October 11, 2000 04:43 |
