Interfaces between blade channel and casing treatment |
September 18, 2017, 02:56 |
Nate Lau
Rep Power: 10 |
Dear all,
I made a 'One-channel' simulation in CFX to check the effect of casing treatment and the configuration is showed in the Pic1 in attachment. I want to link the two interfaces highlighted by green color with different configuration, by 'General Connection ''Frozen Rotor'. The whole mesh is completed in Numeca. Firstly, there is a tip in CFX-Pre: In Analysis 'Flow Analysis 1' - Domain Interface 'Boutlet_Outlet': Pitch Change option 'Automatic' is not valid if side 1 or 2 of the interface has a 360 degree or greater pitch angle, zero radius, mesh faces normal and parallel to the rotation axis, or mesh faces at the hub curve (low radial or axial position) which are thin in the radial or axial direction. So, I set pitch ratio to be 1 then. But in CFX there is also error message, showed in the Fig2 in attachment. Until now I cannot find the mistake... I do not know how to set Pitch Change in CFX-Pre for my case. |
September 18, 2017, 08:27 |
Rep Power: 144 |
Have you read the FAQ: https://www.cfd-online.com/Wiki/Ansy...do_about_it.3F
The floating point error might have nothing to do with your question about pitch ratio. |
September 20, 2017, 08:27 |
AHMAD
Rep Power: 13 |
I think your casing treatment domain and rotor domain should perfectly overlap if you choose pitch ratio = 1.
Try reading the manual again. |
September 20, 2017, 23:36 |
Nate Lau
Rep Power: 10 |
Thank you. The suggestion helps me.
casing treatment, pitch change, rotor-stator |
