writing expression result in a text file in CFD-Post
Old   September 14, 2017, 05:28
Question writing expression result in a text file in CFD-Post
Shafa HN
shafa_hn is on a distinguished road
I need to open result files automatically, calculate the "expression" and write down the result in a text file. But, when I use CCL commands like the following only the name of the expression ('TPR') is exported to the file, not the value of the expression. I need a command to export (to tmp.txt) the calculated value of TPR. I appreciate if any can help me.
!$outfile = "tmp.txt";
!open(OUT, ">$outfile");
!$tpr = TPR;
!print OUT $tpr;
!close(OUT);
PS: TPR is an expession defined before in CFT-post expression list which is total pressure ratio here.
shafa_hn is offline   Reply With Quote
ccl, cfd-post
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 18:18
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 18:18
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 12:46
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
