High pressure flow
Old   November 5, 2002, 23:20
Default High pressure flow
David
The fluids are runing through a horizontal pipe under high pressure and high temperature, for example, 20atm. How to specify "Reference Pressure" in Domain Options and how to specify "Static Pressure" on the Outlet boundary? Thank very very much for your answers.
Best regards, David
Old   November 6, 2002, 01:26
Default Re: High pressure flow
sheetal
Dear David, If you are using TASCflow you can give "opening" instead of "outlet" to give static pressure at outlet. Otherwise by continuity equation calculate velocity at out and give total pressure BC at outlet.
regards,
sheetal
Old   November 6, 2002, 18:21
Robin
Specify your Reference Pressure as 20 [atm] and your static pressure at the outlet to the desired static pressure minus the reference pressure.
Robin
Old   November 6, 2002, 18:59
David
Thanks Robin. But how can I know the desired static pressure? If the horizontal pipe is very long with a quite narrow diameter, can the desired static pressure be zero? (because Pstatic=density*g*h, since h is near zero).
Regards David
Old   November 11, 2002, 09:46
Robin
David,
You have your equations mixed up. Pstatic = density*g*h is used to calculate hydrostatic pressure. If you're pipe were standing straight up and the fluid was not moving, that is the pressure distribution you would see. You may want to bone up on your fluid mechanics before continuing.
One end of your pipe must be open to atmosphere or some sort of resevoir. Use the sensible pressure for that boundary. In the end, since your flow is most likely incompressible, it doesn't really matter what you set your reference pressure to. If you specify a static pressure at your outlet equal to zero (relative), the remaining pressures will be reported relative to that outlet. That should suffice.
Regards, Robin
Compressible flow, no data at the outlet mireis FLUENT 6 September 3, 2015 03:10
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
Mass flow BCs and Pressure differential BC CFDLife CFX 5 January 26, 2009 08:14
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
pressure gradient term in low speed flow Atit Koonsrisuk Main CFD Forum 2 January 10, 2002 11:52
