November 3, 2002, 09:30 |
Pressure level ?
I get the following warining in the beginning of the simulation: The pressure level was not set by any of the boundary conditions. Zero relative pressure will be set at the first finite volume equation in domain "tuborg1". All boundary are defined as inlet and outlet and a background pressure has been defined to 1.01E5. Does it has any influence on the solution ? Regards Peter |
November 3, 2002, 20:44 |
Re: Pressure level ?
If you are using an Ideal Gas this will influence the solution since some of the fluid properties depend on the absolute pressure level. In this case, you should try to change one of your boundary conditions so that the relative pressure is set somewhere, e.g. change a velocity inlet to a velocity and pressure inlet. Mike
Pulsatile pressure inlet with pressure outlet | a.lynchy | FLUENT | 3 | March 23, 2012 14:45 |
UDF to define or adjust pressure??? | engahmed | FLUENT | 0 | July 6, 2010 18:19 |
pressure BC-natural convection | engahmed | Main CFD Forum | 0 | June 16, 2010 12:38 |
pressure in Natural convection??? | engahmed | FLUENT | 0 | June 14, 2010 13:51 |
Pressure Rise Error | emueller | CFX | 0 | May 5, 2009 12:08 |
