meshing a sharp edge
Old   November 2, 2002, 05:39
Default meshing a sharp edge
line
I am already frustrated by the meshing process. Can anyone suggest a reading/hint/trick for me to handle the job. Should I be an expert of topology to work on this code?
I have 2 problem, please give me some idea. Thanks (1) I have to model a wind tunnel with 60m long and testing cross section is 3mto 2m. Inside the turning angle, there is a 10 guard vane which is 8mm thick. That means the overall dimension range from 8mm to 60m. Will it cause problem to the code if the size different from 3~4 magnitude of order? I already notice that, from Dave, I can use the thin film to handle the 8mm guard vane. But I have 10 guard vane? It seems it work for 3 guard vane but no more than 3!!!
(2) I have an very geometry which is for teaching purpose. It is defined by the point as a near triangle shape(with 2 side is straight line and one side is parabola) normal to x-plane with one edge connected to the sqaure in other plane. I know there is a small angle problem. I have try to put one more point into the parabola side to construct a trimmed surface. But the meshin process still fail!!!!!
Is it common problem to the code?
Thanks line
Old   November 2, 2002, 08:03
Default Re: meshing a sharp edge
Astrid
Regarding problem 1:
- 3 to 4 orders of magnitude should not be the problem. I wonder what the effect of 8 mm will be on a wind tunnel of 60 m, and the other way around, but that is a different question.
- It should be possible to define 10 subdomains which gives you the possiblity to define 10 thin surfaces. Forget inflation on the thin surfaces.
- How are your surface meshes?
- Did you get a volume mesh if you write out a definition file without inflation?
Regarding problem 2:
- Does the meshing problem fails when you write out a definition file or does it already fail when you write out a surface mesh.
- Standard question: have you tried the AFI surface mesher instead of the standard Delauney surface mesher?
- How worse is your worst angle?
Astrid
Old   November 2, 2002, 12:19
Hannah liang
My experience is to use the 8mm gap of guide vane instead of the thin wall, then build B-rep solid in this area. In this way you can add inflation when you write the def.
[ICEM] Hole near sharp trailing edge of airplane/wing geometry jlichtwa ANSYS Meshing & Geometry 2 September 21, 2010 16:19
Which trailing edge is correct for meshing of aerofoils for CFX LSC CFX 0 May 10, 2009 13:45
Structured mesh of a 3d sharp trailing edge Gilles Main CFD Forum 2 May 23, 2008 14:23
