November 1, 2002, 22:04 |
Advice for convergence problem
Hi, everybody. I am simulating a gas/liquid two-phase multicomponents flow with reactions in liquid phase. After 70 steps, the solver was terminated with overflow errors. Could anybody please give me some advice how to get a converged solution? Many thanks.
David |
November 1, 2002, 22:56 |
Re: Advice for convergence problem
Need some more details really... If you look at the results before the solver overflows (maybe at the 60th iteration) what do they look like? Is there a particular location where it looks totally unrealistic (maybe you get huge velocities near an inlet?). What's the physics setup (which multiphase models, drag models), what type of flow is it (e.g dispersed gas in a continuous liquid?). Mike
November 2, 2002, 04:29 |
Thanks a lot, Mike. Yes, the flow is a dispersed gas in a continuous liquid in a pipe. The inlet velocity is very slow, about 0.7cm/sec. I use Schiller Naumann Drag model.
Regards David |
November 2, 2002, 14:26 |
That is slow - what's the Reynolds Number? Could it be Laminar flow but you are applying a turbulence model? Mike
November 3, 2002, 04:00 |
Good suggestion, I'll try. Thanks Mike.
David |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 20:42 |
Can I solve this problem by Fluent? | Kai_kc | FLUENT | 1 | October 27, 2010 06:29 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 07:29 |
Periodic flow boundary condition problem | sudha | FLUENT | 3 | April 28, 2004 09:40 |
Need advice for intercooler problem | joon | Siemens | 5 | September 14, 2003 01:06 |
