How to define source points as spargers for bubble column modeling? |
Roy
Rep Power: 9 ![]() |
Hello every body,
I'm completely new in CFX. I;m going to start my post PHD thesis on bubble columns using Eulerian approach. But in case study I have a serious problem. I Don't know how to define sparger as source points in the column? now my question is: -Does any one here knows how to model sparger using source points? -Do I need to use an UDF? YOUR HELP IS DO MUCH APPRICIATED. |
Rep Power: 144 ![]() ![]() ![]() ![]() |
Can you define it as just a normal inlet boundary?
Roy
Dear ghorrocks Thanks for your fast response, Unfortunately NO...I should model it as a source point, I heard that there is such an ability in CFX to define a source point by giving it some coordinates and even angles for the flow exiting from sparger. I contacted with some one who wrote this in his paper and he said that there is no need to write a UDF because there is a tool for this in CFX. I just don't know where to find it and he couldn't remember where was this tool box? In case you have worked CFX, Have you ever seen such a thing? |
Rep Power: 10 ![]() |
You can use source point in CFX. The button is the blue square with a red dot.
I also show what settings you can/have to set. Mass flow and a velocity in some direction. Good luck ![]() |
Roy
bubble column, source point, sparger design |
Custom Thermophysical Properties | wsmith02 | OpenFOAM | 4 | June 1, 2023 14:30 |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 17:34 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
Installing OF 1.6 on Mac OS X | gschaider | OpenFOAM Installation | 129 | June 19, 2010 09:23 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
