cfx-pre
Old   August 23, 2017, 10:11
Default cfx-pre
xuhaoyang
compressor is on a distinguished road
How to modify gas constant or special heat ratio in CFX-Pre?
compressor is offline   Reply With Quote
Old   August 23, 2017, 10:18
Default How to modify gas constant or special heat ratio in CFX-Pre?
xuhaoyang
Thanks
Old   August 23, 2017, 11:12
Opaque will become famous soon enough
Why would you do that?
The gas constant should never be modified. It is the universal constant divided by the molar mass. Therefore, the knob to change is the molar mass
The specific ratio is Cp/Cv, and Cv = Cp + R; therefore, nothing to change.
It is bad practice to change dependent quantities. It usually ends up with some thermodynamic inconsistency downstream.
I would think twice before changing such quantities.
Opaque is offline   Reply With Quote
Old   August 24, 2017, 00:21
Default I must modify gas constant or specific heat ratio
xuhaoyang
I must modify gas constant or specific heat ratio.Because I investigate the effect of fuild property, such as operating characteristics when the gas constant is constant and specific heat ratio is different.
Old   August 24, 2017, 00:22
xuhaoyang
Old   August 24, 2017, 09:25
The gas constant is not a fundamental thermodynamic parameter, neither is the specific ratio.
If you are modifying such parameters, you are effectively modifying the molar mass (different material or composition), and one of the specific heat variables.
Old   August 25, 2017, 07:55
Default How to modify gas constant or specific heat ratioinCFXPre?
xuhaoyang
You means that I should modify gas constant or specific heat ratio by changing molar mass or specific heat capcity(constant pressure) in CFX-Pr?
Command editor is not visible in CFX Pre 17.2 Windows 10 hmdl CFX 3 December 23, 2020 14:17
Green Cones appearing in CFX Pre lionelopittmanjr CFX 1 February 25, 2017 05:46
CEL expression in CFX pre Jane92 Main CFD Forum 1 June 3, 2016 02:48
Only two turbulence options available in CFX Pre Jack001 CFX 5 March 30, 2016 02:47
air ideal gas in CFX Pre wangy1767 CFX 9 October 1, 2012 07:55
