August 18, 2017, 06:34 |
What does the error message mean?
Nate Lau
Rep Power: 10 |
OUTER LOOP ITERATION = 1 CPU SECONDS = 5.096E+01 ---------------------------------------------------------------------- | Equation | Rate | RMS Res | Max Res | Linear Solution | +----------------------+------+---------+---------+------------------+ ---------------------------------- Error in subroutine CALVAR : Error calculating Rotation Velocity GETVAR originally called by subroutine get_DOMVEL +--------------------------------------------------------------------+ | Writing crash recovery file | +--------------------------------------------------------------------+ Details of error:- ---------------- Error detected by routine FNDFIL CFNAME = * CRESLT = OLD Current Directory : /FLOW/SOLUTION/TSTEP1/CLOOP1/ZN1/VERTICES +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver exited with return code 1. No results file | | has been created. | +--------------------------------------------------------------------+ End of solution stage. |
August 18, 2017, 06:49 |
#2 | |
Rep Power: 144 |
August 18, 2017, 08:23 |
Nate Lau
Rep Power: 10 |
Dear ghorrocks,
Thanks for your reply. I also mention this sentence but I still cannot find where is the improper setting in CFX... This error takes place at the first interaction. |
August 18, 2017, 08:50 |
Rep Power: 144 |
Please post your CCL and/or output file.
August 25, 2017, 03:03 |
Nate Lau
Rep Power: 10 |
It may be related to the grid... I did the mesh again and there is no error message.
cfx |
