September 12, 2002, 15:10 |
flat tetrahedral elements
Has anyone got got an idea of how to prevent flat thrahedral elements in the CFX 5.5.1 mesh? The problem is the inflation on surfaces that are 180mm apart with element size 20mm. On their own the surfaces inflate with no problems, but if inflation is turned on on both sides the problem occurs. Any hins, suggestions and thoughts are welcome...
Rene' |
September 12, 2002, 17:06 |
Re: flat tetrahedral elements
Assuming your multiplication factor for the inflation layer is equal to 1, your inflation layer will be 20 mm thick. So the space left is 180-2*20 = 140 mm. In 140 mm, 10 elements of 20 mm (height = sqrt(2)) do not fit in exactly, although I would not at all expect a problem with 10 elements. However, you can try a smaller edge length (using a mesh control), or the AFI surface mesher, if you have badly parameterised surfaces.
Astrid |
[ICEM] Hybrid mesh for 2D boundary layer | Bigio | ANSYS Meshing & Geometry | 33 | November 18, 2019 09:15 |
What is the sequence of nodes in a tetrahedral element | rvacharya | ANSYS Meshing & Geometry | 0 | February 3, 2011 06:52 |
[ICEM] Negative Volumes & 7 node HEXA elements | mr_stoked | ANSYS Meshing & Geometry | 1 | September 21, 2010 12:45 |
Penetrating elements in extruded mesh | Michael P | CFX | 2 | May 20, 2005 08:06 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
