Multiphase Flow - CFX Solver
Old   August 14, 2017, 13:43
Default Multiphase Flow - CFX Solver
MissCFD is on a distinguished road
Does anyone confirm me what the variables below correspond:
- Mass-Water is for Continuity Equation of the Water ?
- Mass-Vapor is for Continuity Equation of the Vapor ?
- P-Vol is for Volume Conservation Equation ?
(These variables can be seen each iteration of a simulation)
And when my domaine Imbalance exceed 1% like below, it is not good, right?
| Mass-Water-Domain dt |
Boundary : AirInlet 1.5649E-14
Boundary : outlet -3.6559E+02
Domain Interface : bl dt (Side 2) 3.9123E+02
Domain Imbalance : 2.5637E+01
MissCFD is offline   Reply With Quote
Old   August 14, 2017, 19:16
Mass-Water is the mass fraction equation for water.
Mass-Vapor is the mass fraction equation for vapour.
P-Vol is the pressure correction/mass conservation equation.
A domain imbalance of more than 1% MAY indicate inadequate convergence. You need to do a sensitivity study to find out in your case whether that is acceptable for not. But for most applications the 25% imbalance you indicate would be unacceptable.
ghorrocks is online now   Reply With Quote
Old   August 16, 2017, 13:47
Thank you very much for your response.
For a good understanding:
- if there are an imbalance of 25% in the mass fraction equation for water that means that there are more mass that goes in or out of this domaine, right ?
- if there are an imbalance of 25% in the W momentum equation for water that means that the equation \sum F_{z}=ma_{z} is not correctly applied, right ?
Old   August 16, 2017, 18:40
An imbalance in a mass fraction equation means that conservation of that mass fraction has not been achieved, that means that the sum of all mass flows does not equal zero.
An imbalance in the momentum equation means that momentum is not conserved. Momentum is mass*velocity in its simplest sense.
Old   August 28, 2017, 03:53
Default Depends on the setup
Thomas
Meister is on a distinguished road
[QUOTE=MissCFD;660955]Thank you very much for your response.
It depends on your setup. If you use Multiphase with Cavitation, water is able to evaporate (water enters the domain but doesn't quit it anymore). If your setup is also transient you haven't yet established a steady state status -> It doesn't mean that your simulation is unphysical.
Meister is offline   Reply With Quote
How is the accuracy using VOF (pressure based solver) on supersonic flow air_fun Fluent Multiphase 1 August 25, 2021 00:59
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 07:54
CFX Solver Reynolds Number haider760 CFX 2 March 4, 2012 22:05
Ansys 11.0 CFX - solving electric potentials and multiphase flow cfd_multiphyiscs CFX 2 March 10, 2010 13:43
Mass flow and U-Mom flow in CFX Zhihua Xie CFX 0 September 3, 2007 09:49
