September 10, 2002, 05:26 |
CFX5 db files migration UNIX-> Windows 2000
Has anybody a workaround for reading .db files generated under AIX 4.3.3 (IBM UNIX) in CFX5build running under windows 2000?
September 10, 2002, 08:18 |
Re: CFX5 db files migration UNIX-> Windows 2000
Hi Bart,
The only time you can't do this is when you are trying to open a database created by an older version of the code. Otherwise, the database translation should occur just fine between AIX and Win2K. Robin |
September 10, 2002, 10:26 |
You mean it can be done with CFX 5.5.1 or with 5.5?
September 10, 2002, 17:31 |
Bart,
I think Robin tries to explain the following. Unix 5.5 -> Win2000 5.5 OK Unix 5.5.1 -> Win2000 5.5.1 OK Unix 5.5 -> Win2000 5.5.1 Not OK I tried it with Linux -> Win2000 and conversion worked out that way. Astrid |
September 10, 2002, 22:34 |
That is correct.
Robin |
September 11, 2002, 02:38 |
Great thanks,
I must say that this is a better way to communicate with the CFX helpdesk than the direct way. keep up the good work Robin. |
September 16, 2002, 07:22 |
I just hope Robin gets paid for all his extra work !! Dave
UDF issue | MASOUD | Fluent UDF and Scheme Programming | 14 | December 6, 2012 13:39 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
Linking between my own code and CFX5 in Windows | Se-Hee | CFX | 2 | May 17, 2007 08:52 |
