Time Stepping Control
Old   September 4, 2002, 08:16
Default Time Stepping Control
Dave
Hi Everyone, I have a question regarding which time stepping methodology to apply to my model. I have a buoyant jet release (approx 170 m/s) into room defined as a Subdomain which has side walls and a top and a bottom, but no end walls. The room is located in a domain which has an ambient wind of 10 m/s blowing parallel to the open ends of my room. My question to the group is:
What would be the best Time stepping Methodology to apply to achieve convergence as quickly as possible ?
I have tried using Auto Time stepping, this unsupprisingly has chosen very small time steps and convergence has not been great. Would I be better to use local time stepping to start with (as there is a large variation in the velocity field) and then swap over to physical time stepping once I've achieved a converged solution ??
Your imput would be most appreciated, Cheers and Thanks
Dave
Old   September 4, 2002, 13:34
Default Re: Time Stepping Control
Nandu
have u tried using the swap between local time stepping and physical timestepping? I have a similar problem but the jet is a supersonic jet into still air. I have had no success with either physical or auto timestepping. local timestepping has give me a converged solution, the validity of which i still doubt.
regards n menon
Old   September 5, 2002, 06:39
Dave
Hi Nandu, cheers for the suggestion, I'll give it a try. Dave
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 17, 2019 00:12
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
local time stepping and pseudo time phil Fidelity CFD 0 February 27, 2006 17:26
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
