About combuestion in CFX5.5
Old   August 20, 2002, 22:38
Default About combuestion in CFX5.5
ray.hoo
hi, everyone I can not utilize the combuestion model in CFX5.5. I can not use it to calculate the combuestion of multicomponent gas fuel. The component of gas fuel is a mixture of low molecular weight hydrocarbon including olefin, ethane, propane, butane, etc. The problem seems to be so easy to handle CFX4.3. But I do not know how to solver it in CFX5.5
Old   August 21, 2002, 22:05
Default Re: About combuestion in CFX5.5
Michael
Hi Ray, have you completed the Combustion tutorial (#18)? Regards, Mike
Old   August 21, 2002, 23:31
ray.hoo
Dear Mike: Thank you at first. But I think I did not express clearly which problem I must solver. The Combustion tutorial (#18) is very simple. And the gas fuel is just one combustible component--methane. The mixture in tutorial (#18) is the air and the methane. But THE multicomponent gas fuel what I refered to is the methane and other combustible component like butane, ethene, etc. THE multicomponent gas fuel does not include the combustion-supporting like air and oxidant. Maybe I did not utlize the tutorial efficiently. Then can you give me a hand ?
Old   August 22, 2002, 17:22
Michael
Have a look in the <CFXROOT>/etc/5.5.1/REACTIONS file - hopefully this should be of some help?
Old   August 29, 2002, 10:26
ray.hoo
I have tried but failed again. Have you done something about this? If it is ,Tell me how you do to solver the problem, Please,
Old   August 29, 2002, 23:12
Michael
Hi Ray, sorry - i haven't ever tried to set a case similar to the one you describe. I believe the REACTIONS file allows you to define custom reactions, but i haven't tried to do this. Hopefully somebody else on here will know more. Regards, Michael
Old   August 30, 2002, 03:51
ray.hoo
Then who can help me ?
Old   September 8, 2002, 15:24
Sharks
The reaction/combustion modeling in CFX-5 is a little different than in CFX-4. In CFX-5, there is no limit to the number of fuels and oxidants you can solve in a single calculation; you simply include the species you want to model for each reaction.
If you want to model more than one reaction, then you include multiple reactions within a single reacting fluid which contains all the required species. Additionally, if you want to model a reaction in a number of steps, you can include the steps within a single reaction.
Admittedly, the tutorial in the CFX-5 manual is a little limited since it only deals with a simple one step reaction.
I would take Michael's advice and familiarise yourself with the REACTIONS file, and the Command File of the tutorial. This should give you all you need to model your physical situation.
Fortran compiler in CFX5.5? David CFX 1 November 19, 2002 06:47
Is this a possibility in CFX5.5?? Ivan CFX 0 July 31, 2002 12:14
creating geometry in CFX5.5 adam CFX 5 July 17, 2002 10:55
CFX5.5 Solver Sara CFX 8 July 12, 2002 07:49
CFX5.5 on laptop? HGG CFX 1 January 28, 2002 17:05
