Solution Method & turbulent intensity in CFX 5.5.1
Old   August 14, 2002, 20:39
Default Solution Method & turbulent intensity in CFX 5.5.1
hamza albazzaz
hi
I want to know what type of Alogrithem solution method used in CFX5.5.1 is it SIMPLE method?
and what does the defult number of turbulent intensity use in the CFX 5.5.1?
thank you
Old   August 26, 2002, 15:46
Default Re: Solution Method & turbulent intensity in CFX 5
Neale
No, it's not SIMPLE. CFX-5 is a pressure based coupled flow solver, i.e., solves for u,v,w and p at the same time. There have been threads on this in the past, just search the archives.
The default turbulence levels are given in the manual. 3.7% intensity I think
Neale
Old   August 27, 2002, 17:05
Jhonny
Greetings to all, The previous answer is not certain 100%. Due to the explained thing previously they can be the schemes (SIMPLE,SIMPLER, SIMPLEC, PISO) But with certain details. I hope that another people us of a good answer to near of solution scheme. Best regards, Jhonny
Old   August 28, 2002, 11:09
Neale
SIMPLE and its variants, as well as PISO are all segregated approaches. CFX-5 does not draw on these approaches at all and that *is* 100% certain. In fact, there is no option to use a segregated approach. I mentioned that the approach in CFX-5 has been discussed before in the CFX Forum:
http://www.cfd-online.com/Forum/cfx_...e.cgi?read=934
Neale
Old   August 28, 2002, 13:12
Jhonny
Hi,I follow without understanding the algorithm of solution???? Please search: www.gre.ac.uk/~physica/phy2.11/theory/sode11.htm see Momentum-pressure coupling. Best regards.
Old   August 28, 2002, 13:16
Jhonny
excuse me the web is wwww.gre.ac.uk/~physica/phy2.11/theory/node1.htm
Old   August 30, 2002, 17:28
Robin
Hi Jhonny,
As Neale pointed out, CFX-5 uses a coupled approach, not segregated. The SIMPLE and SIMPLEC algorithms are a means to account for pressure-velocity coupling between segregated equations.
SIMPLEC is an extension to SIMPLE developed at ASC (now part of CFX). For more on this see:
Van Doormaal, J.P.; Raithby, G.D.,"Enhancements of the SIMPLE Method for Predicting Incompressible Fluid Flows", Numerical Heat Transfer, Vol. 7, pp. 147-163, 1984.
This approach was later dropped in favor of solving for the coupled mass-momentum equations simultanously using a coupled algebraic multigrid approach. For a paper describing the approach, see the following pubished by ASC in 1988:
Hutchinson, B.R.; Galpin, P.F.; Raithby, G.D., "Application of Additive Correction Multigrid to the Coupled Fluid Flow Equations", Numerical Heat Transfer, Vol. 11, pp. 133-147, 1988.
Regards, Robin
Old   June 29, 2011, 13:39
al mazdeh
amazdeh is on a distinguished road
Originally Posted by Robin
;64560
Hi Jhonny,
Regards, Robin
Hi Robin
I don't seem to be able to find this article-do u have it?-thanks
amazdeh is offline   Reply With Quote
CFX Treatment of Laminar and Turbulent Flows Jade M CFX 18 September 15, 2022 08:08
fractional intensity and turbulent intensity in CFX Nick R CFX 1 April 6, 2013 12:23
Turbulent Schmidt Number in Ansys CFX 12.1 DiddyPablo CFX 7 May 23, 2011 12:20
k-epsilon: Defining turbulent intensity and length scale? klausb OpenFOAM 0 January 23, 2011 08:28
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
