problem during export of particle tracking data (good decription of the problem) |
August 1, 2017, 11:23 |
Arthur
Rep Power: 11 |
Dear Sirs!
I have a problem with export of particle tracking data. All the information you can see on screen attached. Below a description of the problem I perform a steady state simulation (2 stator domains and 1 rotating domain (Interface model is Frozen Rotor)) with 2 solid particles injected from the inlet boundary condition. The problem occurs after export of a file with some PT parameters. You can see a part of the file with PT traveling distance as a function of Z coordinate. As soon one particle interserts border between two domains (z coordinate equals to 92.6 mm), CFX sets to zero the values and retursns to inlet section (z coordinate equals to 0 mm) for writing parameters for the second particle. All I want is writing all the parameters for one particle through the domains from inlet to outlet in one column. Hope you can help to solve this problem Arthur |
cfx, export data, particle tracking |
Export Particle Data From Fluent to Paraview | liliana | FLUENT | 2 | November 18, 2016 09:14 |
Lagrangian Particle Tracking in Eulerian-Eulerian Multiphase Flow | DarrenC | CFX | 5 | April 7, 2016 14:50 |
Unable to install OpenFOAM 1.6-ext | Maimouna | OpenFOAM Installation | 23 | May 8, 2014 05:47 |
problem about export data | Rui | Siemens | 2 | January 18, 2007 22:16 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
