July 26, 2002, 20:43 |
about roughness hight Yr
Hi, CFX friends, who knows how to specify the roughness (Yr)of the wall in order to simulate the resistance of duct when I failed to use inflation near the wall in CFX 5.5? Thanks a lot.
Hannah |
July 27, 2002, 02:33 |
Re: about roughness hight Yr
Hi Hannah, if I understand this correctly, then you are trying to avoid the use of wall inflation and set a roughness height instead? I'm assuming that your near-wall mesh is very course then? The roughness height setting is not meant to be used as a substitute to a fine near wall mesh. Using a no-slip wall will simulate the resistance of the duct. If the duct is not smooth, then also use a roughness height to simulate this. You should still use a fine near wall mesh for accurate results (together with scalable wall functions). The roughness height setting is based on an equivalent sand grain roughness - see the reference in the documentation in the roughness height section. Hope this helps, Michael
July 27, 2002, 12:18 |
Hi, Michael, thanks for your replying. Actually, the duct I simulated has a definite roughness. In order to get the result as accurately as possible, the inflation should be used definitely, at the same time, roughness should be considered. My problem is, firstly, when I use the inflation, the def. file cannot be written, but when I delete the inflation, it can be writen. So frustrated! Secondly, how to specify the Yr value in actual case?
Hannah |
July 28, 2002, 22:03 |
Hi Hannah, you specify the wall roughness height in the Wall Boundary Condition Values panel. However, it isn't always available (e.g. with some turbulence models), it will be available for k-epsilon. Note that the actual height of your duct roughness is NOT the height you specify - you specify an equivalent sand grain roughness. Not sure about writing the def file with inflation. If you are using 5.5.1 try the new inflation option where you specify the height of the first layer and the number of layers (see doc). It give a smoother transistion to the tet mesh. Hope this helps, Regards, Michael
July 29, 2002, 06:08 |
Hi Hannah, Is you model just of a plane duct, with no other more complex geometry attached to the duct or going through the duct ? Do you get a mesh out even when you specify including inflation in the definition file setup form within build or do you just get an error ? regards Bob
July 29, 2002, 10:22 |
Hi, Bob, sometime I can get a mesh out with inflation, but most time I cannot. Some error code will come out. I even cannot understand the meaning of the code. Where I can check or read the code and get the meaning of the error code in CFX 5.5?
Thanks Hannah |
July 31, 2002, 07:55 |
Hi Hannah, some of the error messages are included in the online help pages, some are not. Some of the error messages can be quite cryptic. Why don't you post your error message, then some one may be able to help with it ??
July 31, 2002, 10:26 |
It's a good idea.Bob.
Thanks a lot. I will do in this way. Hannah |
nutRoughWallFunction and Surface Roughness Documented | AlanR | OpenFOAM Programming & Development | 64 | January 6, 2024 08:13 |
Laminar flow and wall roughness | junbbung | FLUENT | 2 | November 26, 2022 22:22 |
Setting of Roughness Constant and Height | Sing | FLUENT | 7 | June 23, 2021 15:26 |
NACA standart roughness | DAK565656 | Main CFD Forum | 2 | August 24, 2005 01:47 |
Roughness adaptation in CFX 4.4 | Bart | CFX | 1 | May 2, 2003 09:32 |
