Puzzle encountered when using opening B.C. for calculation domain |
July 24, 2017, 04:14 |
Zeng
Rep Power: 9 |
When applying opening boundary condition, for example, to the domain inlet, I could choose either opening Pres. and Dirn or Static Pres. and Dirn. I do know the difference but the question is when back flow happens, the pressure value I specified is taken as static pressure(if I choosing latter one). Does it really reflect the real conditions? Actually the pressure I specified is the ambient pressure, which in any case is the total pressure. So is this treatment inappropriate or if I was wrong with something?
July 24, 2017, 07:48 |
#2 | |
Rep Power: 144 |
July 24, 2017, 08:23 |
#3 | |
Zeng
Rep Power: 9 |
The ambient pressure is P0, and this value is exactly the total pressure specified for the direct flow of the inlet. But if back flow happens, to my knowledge, the static pressure should lower than P0 because of the fluid velocity. So, is the opening pressure and direction a compromise or approximation? |
July 24, 2017, 08:30 |
Rep Power: 144 |
Yes, it is an approximation. But in your situation it sounds like a better approximation than the other options.
July 24, 2017, 10:20 |
Zeng
Rep Power: 9 |
What if the difference between the total pressure and the static pressure is relatively large. How to deal with it?
July 24, 2017, 19:49 |
Rep Power: 144 |
If that is realistic then that is what you have to deal with - it is likely to cause convergence difficulties so it will be a little difficult to handle.
If this causes problems then move the boundary to somewhere the conditions are also known but the situation is not so radical. If this is an atmospheric boundary this could be to move the boundary further out into the atmosphere where the velocity can dissipate and reduce, as this will reduce the difference between total and static pressures. |
boundary conditions |
Domain format problem on airfoil flow simulation | andrenonaka | CFX | 14 | December 7, 2015 01:42 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 08:59 |
CFX Solver Memory Error | mike | CFX | 1 | March 19, 2008 08:22 |
Opening B.C. display in POST | Felix | CFX | 0 | August 15, 2007 16:08 |
effect of geomertry domain on Far-field B.C | laith | Main CFD Forum | 0 | October 23, 2006 18:42 |
