Transient Simulation, wall placed at inlet/outlet |
July 19, 2017, 04:17 |
Jeet
Im doing a simulation of an intake plenum with inlet and initialization pressure as 101325 Pa. outlet is a function of seconds vs mass flow in kg/s
when the inlet valve is open mass flow is positive and hence i have no trouble but when the mass flow is negative due to the valve closing. i get an notice that a wall has been placed at inlet and outlet and depending on the value it says some % of area is blocked. I Believe this is done to prevent reverse flow. when this persists for multiple timesteps cfx gives a return code of 1 and the run ends with no results . Note : in my geometry only the plenum and runner is modelled. values of mass flow are realistic ranginf from 0.03 to 0.18 kg/s . modeled as SST |
July 19, 2017, 07:10 |
Maxim
Rep Power: 13 |
have you read the FAQ?
https://www.cfd-online.com/Wiki/Ansy...f_an_OUTLET.22 Post pictures of your setup and post the full error message (out-file) so that we can help you properly |
air intake, cfx, plenum, transient, wall placed at inlet |
A question about a simple ceiling fan simulation (no inlet/outlet BCs) | Tellur | STAR-CCM+ | 3 | June 9, 2017 09:34 |
Multiphase simulation of bubble rising | Niru | CFX | 5 | November 25, 2014 14:57 |
Exporting data of transient simulation DURING a simulation, at user locations ? | Milan2013 | CFX | 0 | April 18, 2014 04:47 |
Boundary Conditions - Transient Simulation | miki256 | CFX | 2 | May 18, 2012 02:22 |
how to identify transient simulation converged | littlelz | CFX | 5 | January 27, 2009 19:13 |
