Rotor domain with bleed slot
Old   July 17, 2017, 10:07
Default Rotor domain with bleed slot
AHMAD
afikr is on a distinguished road
Hi All,
I am trying to simulate a rotor with a bleed slot at the endwall.
Right now I am using ICEM to mesh all my domains ( Rotor and Bleed slot). I use an interface to connect the two domains together.
However, I find that this is a daunting task because I need to vary the bleed slot location and the size of the bleed slot.
I am thinking of using TurboGrid to mesh the rotor domain. But I cannot find a way to specify the region at the hub where the interface is located. Turbogrid only gives Hub, Shroud, Inflow, Outflow ,PER1 PER2 and Blade for the mesh region names.
From what I know, I need to have a part/region name before importing my mesh in CFX-Pre. I have always specify the location of the interface in ICEM. Then use connections to specify where I want to have the interface.
Is there a way to just glue the domain together without specifying the regions where the interface is located?
If not, could anybody suggest a better way to do this?
Thanks in advance.
afikr is offline   Reply With Quote
Old   July 17, 2017, 11:38
AHMAD
I think I just found a solution to my problem.
I think I can do this by imposing a non-overlap boundary condition.
https://www.sharcnet.ca/Software/Ans....html#CACIEDFB
Old   May 8, 2018, 11:33
Ruben Bruno
rbruno is on a distinguished road
How did you got it?
rbruno is offline   Reply With Quote
2D slot jet sinkal CFD Freelancers 8 February 17, 2016 06:39
Axial compressor bleed modelling Kishore Main CFD Forum 1 May 28, 2014 21:00
Combustion Simulation in Multiple Slot Burner dharanishb FLUENT 1 March 2, 2014 14:30
Inlet slot for rooms myting OpenFOAM Pre-Processing 11 October 1, 2006 09:02
Slot jet in cross flow. Hamdy FLUENT 0 March 5, 2006 05:04
