Wall function
Old   July 2, 2002, 14:51
Default Wall function
Min-Hua Wang
Hello, All:
Can I use user-defined wall function instead of the default one in CFX-4 environment.
Thanks for any suggestions!
Min-Hua Wang
Old   July 2, 2002, 17:01
Default Re: Wall function
Astrid
Check out the Fortran userroutine USRWTM.
Good luck, Astrid
Old   July 4, 2002, 22:42
Min-Hua Wang
Hello, Thanks.
Do you have any experience to modify wall function to hold the rotationg wall.
Actually, I want to export y+ value from a CFD somution for a rotating wall.
Any suggestion?
MHW
Old   July 5, 2002, 02:59
Astrid
Actually, I don't have experience in that field.
Do you need it for post processing or during the simulation? Where do you want to export it to?
Astrid
Old   July 5, 2002, 13:13
Min-Hua Wang
I need to export it for mass transfer coefficient and I guess I should use a correct version of wall function as well as a correct definition of y+ on rotating plat
Wall function for velocity? johnblund OpenFOAM 3 September 6, 2022 08:22
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 14:06
Need some wall function approaches! yka8150 Main CFD Forum 0 September 22, 2009 00:08
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
