June 30, 2002, 05:06 |
CFX5.5 Solver Error
Hi all,
I'd like to ask a error message from CFX 5.5 Solver. For my problem, at the SEVENTH iteration in the solver, there's a error as follows, ERROR #001100279 has occured in subroutine ErrAction. Message" c_fpx_handler: Floating point exception: Overflow Details of error:- Error detected by routine MAKDIR CDRNAM = CopyDs CRESLT = ILEG Details of error:- Error detected by routine POPDIR CRESLT = ILEG Anybody can help me to fix this problem or give me some ideas or suggestions? Thanks in advance! best regards, Sara |
July 1, 2002, 06:40 |
Re: CFX5.5 Solver Error
Hi Sara, the 7th iteration (Time Step), suggests that it may be something to do with the turbulence model. I've had problems where my model would crash on the 7th time step, however not with that error message (as I recall). There are several possible problems, it may be that the solve can't cope when the turbulence kicks in, if so try running for 20 time steps (or longer) with a laminar set up then restart with your turbulence def file. The error could also be due to a incorrtect model setup, eg your solving the thermal energy equations but have an in appropriate Buoyancy reference density set or something like that !! I've found that this is more often the case than the turbulence problem, but I don't want to speak for everyone. Hope this helps ? Bob
July 3, 2002, 23:20 |
Hi Bob,
Thanks for your suggestion!^^ I think it helps! ^_^ Sara |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 14:21 |
CGNS Compiling | Diego | Main CFD Forum | 17 | December 21, 2014 02:40 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 07:42 |
checking the system setup and Qt version | vivek070176 | OpenFOAM Installation | 22 | June 1, 2010 13:34 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 16:16 |
