Changing Wall Heat Flux in CFX-Pre Doesn't Change Wall Heat Transfer Coef in CFD-Post
Old   October 15, 2019, 09:06
Nourhan Bahgat
Nourhan Bahgat is on a distinguished road
Thanks alot for your help,
these are Mesh file and output file
https://drive.google.com/file/d/1667...?usp=drive_web
Nourhan Bahgat is offline   Reply With Quote
Old   October 15, 2019, 19:16
Please post images directly on the forum, not on third party websites. I cannot view the google drive link you sent as you did not make it viewable (but don't bother fixing it, just post them directly on the forum).
I note that this has a solid and a fluid domain. Make sure the images show these domains clearly.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   October 15, 2019, 20:01
Nourhan Bahgat
Sorry, I have a trouble in uploading this file directly to the forum, now you can access the file on google drive.
Sorry again, I forgot to let the sharing on
Old   October 16, 2019, 18:38
How many elements do you have in the length (z) direction? Isn't the image just interpolating between your very coarse mesh in the z direction?
Old   October 16, 2019, 18:44
Nourhan Bahgat
About 200 element over length 7.8 m
Old   October 16, 2019, 18:53
Let me clarify my comment: You have inlet and outlet boundaries at either end of the domain. I am not sure how exactly how the heat transfer at the boundaries is calculated and it is likely that the different conditions applied at the boundary condition mean the wall heat transfer is modified. Then combine this with your very coarse mesh in the z direction and you get the different boundary condition values smeared a long way along the domain.
Old   October 16, 2019, 18:59
Nourhan Bahgat
Ok, I understand what you say and will modify the mesh element in z direction ...thanks alot for you 🙏🙏
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 01:04
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff swahono OpenFOAM Running, Solving & CFD 10 October 15, 2018 06:43
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 23:22
