July 10, 2017, 15:21 |
How to Calculate added body mass?
srcredchi
Rep Power: 9 |
Can anyone tell me how to calculate added body mass in water using CFX? Thank you.
July 10, 2017, 19:24 |
Rep Power: 144 |
I do not know what added body mass in water is. Please explain what you are talking about.
July 11, 2017, 03:05 |
srcredchi
Rep Power: 9 |
July 11, 2017, 03:10 |
Rep Power: 144 |
I still do not understand what you are talking about. If I have a brick which is 4kg mass and I put it in water then the brick is still 4kg mass. So what is added body mass?
July 11, 2017, 04:34 |
Rep Power: 14 |
July 11, 2017, 05:25 |
urosgrivc
Rep Power: 11 |
I must say that I also dont undestand vhat you meen.
Are you simulating some kind of porous solid or vhat? |
July 12, 2017, 22:30 |
#7 | |
srcredchi
Rep Power: 9 |
srcredchi
Rep Power: 9 |
July 12, 2017, 22:32 |
#9 | |
srcredchi
Rep Power: 9 |
July 13, 2017, 01:49 |
#10 |
urosgrivc
Rep Power: 11 |
Yes but this only aplies if you are calculating it by hand, a simplification to vhat a real CFD simulation is capable of. As I undarstand this shouldnt even be caled added mass but apparent (or virtual yes) added mass and in a transient fluid simulation all this is calculated with the simulation as this doesent exist. Only mass flow, energy conservation and pressure and others matter beacause this ˝vitrual mass˝ is derived from flow properties on or near the wals of an object like velocity, pressure, density and others which are calculated betven milions of nodes you are just not capable to compute by hand.
Just put an empty void in the fluid (where solid is located) accelerate the walls of this ˝apparent solid˝ make it a transient and monitor the force on the wals it is actualy that simple let the computer do the rest of the computational work for you. Make sure that your timesteps are not too long as force walues will than be wrong because of incorect flow properties. |
June 22, 2018, 03:42 |
#11 |
Rep Power: 12 |
It is not CFD but FEA problem, in many FEA packages you can mark some faces of elements as 'underwater', set water free surface position and program will include virtual mass at dynamic analysis. It is widely used in shipbuilding, the difference in eigenvalues can be more than 100%.
Calculate the submerged volume of floating body | mo_na | OpenFOAM Post-Processing | 1 | May 20, 2017 04:09 |
calculate drag coefficient for body moving in waves | mo_na | OpenFOAM Post-Processing | 1 | May 20, 2017 03:56 |
To calculate area averaged species mass fraction from PDF | Bharadwaj B S | Fluent UDF and Scheme Programming | 3 | March 8, 2016 03:22 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 12:19 |
Calculation of added mass in viscous flow | kharati | Main CFD Forum | 2 | February 1, 2006 01:28 |
