June 20, 2002, 07:49 |
will Turbulence affect solution
hi ,
I have this problem, I know the turbulent intensity(10 %) which is higher than the default (5%) for my problem. When I solve this in CFX 5.5 using KE model the solution does not converge.the residuals goes oscillating but does not come down, the things I tried to get it converge are: 1.Increased the physical time step from 1E-4 to 1E-2 s 2. it blows up when I use local time step. global mass imbalance is still 2% one more thing it is rotating frame problem, does any one know what could be the problem? thanks for your time joe |
June 24, 2002, 13:12 |
Re: will Turbulence affect solution
1. You should try decreasing the timestep; 2. You could always start without turbulence, or with a lower turbulence, to get a better intial field for the flow, and then do a restart with turbulence switched on; 3. Is the k-E the most appropriate model (what about k-Omega or the RNG model?)
June 25, 2002, 18:06 |
Oscillating residuals suggest that the problem may be unsteady. Look at a history of forces or any other parameter - are they oscillating over a fixed period.
Steve |
Turbulence postprocessing | Mohsin | FLUENT | 2 | October 3, 2016 14:18 |
smoothSolver diverges - solution in using PBiCG solver? | makaveli_lcf | OpenFOAM Running, Solving & CFD | 3 | September 11, 2013 12:44 |
How calculate a good initial solution for flow field and turbulence | ferdinando.forno | Main CFD Forum | 2 | September 3, 2009 04:31 |
Errors in CFD | Lily Kabanj | FLUENT | 8 | May 1, 2000 07:52 |
turbulence modeling questions | llowen | Main CFD Forum | 3 | September 11, 1998 04:24 |
