June 18, 2002, 17:03 |
How EDM model works in CFX-5?
Hi everybody,
I want to make a simple test with the EDM combustion model in CFX-5. My reacting fluid is Hydrogen Air (H2, O2, N2 and H2O). I've defined N2 as the constraint equation. I have several inlets and I've set the following mass fractions: 0.21 for O2, H2 = H2O = 0. In just one inlet I've set 1. for H2 and 0. for the other species. I'm not using any radiation model. First I've solved the turbulent flow and then I switched off the fluids and tke and epsilon equations. After a few iterations of the energy and mass fractions equations I've noted no presence of the H2O in my solution and no change in the temperature field, ie. no reaction. What did I forget to set? I tested both Bulk Viscosity and Kinematic Viscosity. My initial conditions for the flow are a cold flow converged solution and for the species are "Automatic with Value" : H2 = H2O = 0. ; O2 = 0.21 Thanks in advance, cfd guy |
June 19, 2002, 17:33 |
Re: How EDM model works in CFX-5?
Make sure you have some initial products in the domain. So, try reinitialising the H2O mass fraction to a non-zero value, say 0.01 or something and rerun it.
Set the H2O mass fraction to "Value" in the CCL to do this, rather than "Automatic with Value". Neale |
June 20, 2002, 10:35 |
Thanks Neale,
But I found that the simplest way is to start from the scratch solving all equations together and the combustion effects will appear naturally. However, someone told me that is possible to trick the code and start a combustion problem from a cold solution modifying a simple coefficient in the EDM model. Regards, cfd guy |
about Subgrid-scale model | impecca | OpenFOAM Running, Solving & CFD | 4 | December 20, 2013 10:36 |
"Full" buoyancy model in CFX | Jade M | Main CFD Forum | 2 | March 18, 2010 12:08 |
Reynolds Stress model in CFX vs Fluent | Tim | CFX | 1 | October 7, 2009 06:19 |
where to set CFX Transition Model? | steven | CFX | 6 | January 17, 2007 11:19 |
Use of 1 equation turbulence model in CFX 4.3 | Niels Deen | CFX | 0 | July 19, 2000 08:50 |
